7080 Harmonic balancer pulley help |
Post Reply |
twinsonfarm
Silver Level Joined: 05 Aug 2019 Location: IL Points: 129 |
Posted: 24 Nov 2019 at 1:05pm |
Is there a shim kit for the harmonic balancer pulley fitment on the tapered crankshaft of a allis 7080? We broke a keys and the pulley was free wheeling a little until we got the tractor back in the shed? I don't know how much is worn yet till I get it apart.
Orange Level Access Joined: 12 Sep 2009 Points: 20192 |
Nope. I can see a bad nose on the crank and a bad hub. Never ever seen such a failure. Someone must not have had the bolt torqued properly.
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2257 |
I have never seen a problem like that either. It's kind of important to have that area correct or it can lead to crank breakage. Now that, I have seen, although rare.
twinsonfarm
What is the proper way to stop the crank shaft from spinning while I remove the center bolt or torque to spec?
There's a hole in the bottom of the bellhousing I think you can have a helper shove a big screwdriver up in to catch starter ring gear teeth. The hub you are removing has six 7/16" holes you could install two bolts and stick a prybar thru them. Remove with a good 1/2" impact wrench.
twinsonfarm
Thank you, Jim
About 30yrs ago, I had a 7580 break the oil pump mounting bracket allowing the oil pump to fall down enough to stop turning. Customer was full throttle under load with a chisel plow. Needless to say the red lite came on just before the engine pulled down and locked up. So, resized all the connecting rods and new rod bolts. Align bored the block and installed a new crankshaft. We also did a complete OH and new turbo. When we got the engine back together, it had an awful noise in the timing gears right at 2500 RPM's (right where it runs when working it hard). Run the engine 2700 and the noise was gone and under 2500 the noise was gone. Long story made short, the viscous style vibration damper was bad and this was what failed the oil pump mounting bracket. It also explained why all the A/C compressor brackets were broken and welded along with the alternator brackets. Those viscous dampers were kind of pricey at that time and probably still are, but that cost the Customer a ton of money. The average guy with the radio turned up probably wouldn't have noticed all that extra noise around the front end of the roaring engine while sitting in the cab.
randy
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1180 |
I put a new viscous ring on the crank pulley a few years ago. $400 or so, but rhe pulley was good. Found a name on the old ring and googled it and found a dealer, not AGCO and got one.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8163 |
Pretty sure they are Fluidamper
randy
Vibratech, If i remember correct, is where i got it.
SteveM C/IL
Vibratech is the parent company of Fluidamper
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5529 |
Thanks(1)
We were losing belts on the "81 N6 (670HI). Our man asked us if the belts were getting twisted or were they snapping in two? They were snapping, so we put on the new harmonic balancer as he said and problem solved.
Post Reply | |
