7080 engine problem
iamace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamace Quote  Post ReplyReply Direct Link To This Post Topic: 7080 engine problem
    Posted: 08 Apr 2019 at 7:25pm
My 7080 lost power, won't even go up a hill in 2nd Hi, changed fuel filter, bled injector lines and now it won't even start, tried either, runs somewhat on that but won't keep running on its own, any ideas? Thanks.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 8:52pm
Could be a lot of things. Did you bleed pump after changing filter? Does primer pump up tight? Is primer still tight after spinning engine? Is there a vacuum between filter and tank? Did shutoff cable work it's way in going down the road? Is tank top or bottom feed? How much fuel is in tank? Could be other things.   MACK
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 9:02pm
How was it running before it lost power?
Air restrictions
Turbo failed
Does it have any smoke from the exhaust while your cranking the engine
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 11:53pm
does fuel run freely out of tank or lines? like maybe  the tank is plugged
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamace Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 6:27am
Been smoking a little more than normal this past spring (2018'), changed the fuel filter and found I had to replace the plunger unit for the fuel filter, filter pumped up fine with new plunger, went to field, (fall 2018) engine dying when trying to work ground, but drove home ok, but now nothing, no power and won't start. Tank 2/3rds. full, fuel ran out of hole when replacing the fuel filter. Have fuel at injectors when having the lines broke (5 injectors). Tried starting with air cleaners removed, no help, some white smoke when trying to start but not much like it should be. Besides the added black smoke when it was working, weems like my big problem ( no power) started after I changed the priming plunger for the fuel filter, part of the old gasket in the fuel line??, but fuel ran out of the filter hole when changing the filter?? Thanks.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 7:43am
Take the primer assembly all apart, there are 2 check valves inside it, that like to catch debris and clog fuel flow to the injection pump. The tractor will run fine without the 2 valves in there, they are just for the priming action.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 8:31am
Later 7000 series tractors with the gravity flow fuel supply from the bottom of the tank can be restricted were the hose connects to the filter base. There is an adapter and a 90 degree elbow at the lower corner of the base. This creates a bit of a bottle neck that can restrict fuel flow if there is debris in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamace Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 7:10pm
Will check the main fuel line to the filter, and those valves mentioned, are they in that small housing directly behind the plunger I replaced?, held on with 2 small screws? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 7:12pm
Yes, the primer pump is a small self contained assembly, the plunger sticks out the side.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 9:01pm
The primer screws apart to get the two check valves out. Usual problem with check valves is decree in them cases pump to loose prime.
A vacuum gauge with a clear hose at primer will tell a lot.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamace Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2019 at 7:07pm
Removed the primer assembly and took apart, no dirt or junk, the "O" ring inside is a little flat on both sides and just a little out of round but not that bad, could this be the problem?, I can try to match the size if they are just a normal rubber O ring? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2019 at 7:23am
those orings are standard orings, available from agco, or a pump shop.
