7080 dual PTO install
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 9:42pm
Yes the 2 splined gears go on one end of the shaft and the clutch pack and driven gear go on the other end.  Once you get the splined gears on with the bearing and snap ring installed you press them down against that bearing, that takes up the slack there.  Then on the other end you will install the clutch pack and gear and tighten that stake until you get the preload.  That shaft cannot go all the way through everything as the splines stop it you have to work from each end.  The center of the shaft has 2 orings for pressure flow to the clutch.  Here are a few pages from the FSM might make it a little clearer.
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 6:49am
Thank you. This explains it better than my 8000 series service manual. And the pictures are not blurry.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
PAFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PAFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 3:34pm
Thank you for all the effort in this.  It's really a good thing to have.
For what it's worth,  I archived this post on the internet WayBackMachine just in case...
