7060 spin out rim |
AC 426 power
Topic: 7060 spin out rimPosted: 11 Aug 2026 at 8:00am |
Any tips or advice on how to get the rim off? Never had to deal with one before, got a rusted out spot on my 7060, tire was loaded. Got the new rim but the local field service won’t mess with it. Thanks!
Alvin M
Posted: 11 Aug 2026 at 8:15am |
Take all the clamps off a the rim
Posted: 11 Aug 2026 at 10:02am |
Loosen all the nuts first to the end of each bolt. Smack one or two clamps with a BIG hammer until they POP loose. Do NOT remove the nuts fully until things have popped.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3784 |
Posted: 11 Aug 2026 at 11:58am |
Tire fluid drained / pumped from tube already? Tire still mounted? If so, dismount the tire while rim is still on tractor hub. Tire / tube has been dismounted? If so, then you may not need/want to dismount rim to Fix/repair it? If rusted area involves a rail, maybe just remove that rails clamps only to gain better access?? The solid mounted rim’s inner area offers metal fabricator a great template & work area where new metal can be sized, then hammered to correct contour lines. It’s a sturdy precise bending area(s) so new metal hammered out on its good area should fit right into its repair area? Just use a angle grinder equipped with a thin 1/6” abrasive wheel (4.5”) to cut out damaged area’s bad metal. Using that damaged metal piece as a temple to size a new flat 1/8” metal insert, shaping it over good rim contours, trim it, then weld it in. With tractors trans in neutral, rim can easily be rotated to a working / hammering area, then rotate back to repair area as much as needed. Just gotta have tractor up on solid wood cribbing for it. But tractor is usually already jacked up & cribbed to safety remove tire. Disconnect tractor batteries before welding on its own mounted rim. Edited by AC7060IL - 12 Aug 2026 at 5:49am |
Unit3
Posted: 11 Aug 2026 at 11:37pm |
I don’t think much of your tire store. Isn’t it their job to remover tires and wheels? Call someone else.
