7060 shifting |
summertime
Topic: 7060 shiftingPosted: 08 Dec 2016 at 7:52pm |
I have a 7060 powershift that is starting to grind when shifting into high or low range. What do I need to adjust?
MACK
Posted: 08 Dec 2016 at 8:59pm |
Snap ring has come off spool in inching spool. Need to pull valve body to fix. MACK
Posted: 09 Dec 2016 at 9:16am |
A-C came with an improved design, eliminating the troublesome snap ring that breaks. Whenever I ran into one of them, I'd position things where they belong and spot a small blob of weld on the spools end doing the same thing as the snap ring. Problem solved permanently. If you want to spend the $$$ to update the parts to the newest, have at it.
