7060 question
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: 7060 question
    Posted: 15 hours 11 minutes ago at 2:51am
Hello, yesterday I noticed that although the tractor was in gear—and correctly set to the high range—it wouldn't move forward when I released the clutch. After a short wait, it finally engaged (the gearbox did grind when shifting into gear, so I don't suspect the clutch is the issue).
Furthermore, I notice this happening primarily when the tractor is positioned on a downward slope (nose pointing down); on one occasion, the hydraulic high-low even shifted into the low range on its own while driving downhill. Could this be caused by low oil levels in the "power director" (transmission/range unit), or is there another underlying cause?
During normal operation, I don't notice any issues, and the tractor has its usual power.
Thanks!
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 49 minutes ago at 10:13am
Certain sounds like low oil in transmission. The transmission oil pressure light should have been on,if that is the case. Does the light even work?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 38 minutes ago at 3:24pm
By what you first described im wondering if your hi low cable on the range transmission is worn out stretched or out if adjustment. When it would not move then ground then fell into gear is not good. You need to know its fully egaged
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
