7060 muffler recommendations |
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Topic: 7060 muffler recommendationsPosted: 01 Dec 2025 at 11:14pm |
Hey all,
I need a muffler for one of the 7060s. I see shoup is running a sale right now, was curious if anyone has used one of theirs with success, or if its the same muffler as all states sells for 130bucks. Thanks!
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Posted: 01 Dec 2025 at 11:40pm |
Back in the day ( 426 /7000 series) I would remove the muffler on a brand new tractor for modification while I was prepping it for delivery. I had an 1 3/8" pipe about 3 to 4 foot long that I would slide inside the muffler from each end. I would hammer the muffler up and down on the pipe like driving in fence posts. After enough hammering the spot welds on the baffles (2) inside would break loose and fall out each end, making a straight thru hole for the hot exhaust gases. It didn't really change the sound much at all but, (if I remember right) lowered my exhaust temps nearly 100 degrees F under full load. That didn't answer your question did it ????
Edited by DrAllis - 01 Dec 2025 at 11:41pm |
Michael V (NM)
Posted: 18 hours 53 minutes ago at 11:35am |
I'd be willing to bet they are the same,, more than likely, a stanley...
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8711 |
Posted: 11 hours 18 minutes ago at 7:10pm |
I put a muffler eliminator on my 8070. Hard to say it's any louder than before. That pipe through the hood spews above the cab top so maybe so? Straight pipe it....my open station 220 is another story. It's got a factory 7030 muffler.
JPG AUSTRALIA
Posted: 4 hours 4 minutes ago at 2:24am |
Straight pipe is not loud if done right,keep it the same diameter as turbo outlet,3.5 inch or so ,5inch or bigger will drone. Keep the lenght as least as long as the muffler,no short stack. Ihave mine about as high as indicators on cab.
Edited by JPG AUSTRALIA - 3 hours 60 minutes ago at 2:28am |
