7060 Jack Bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 7:05am
The original post was for  7000 series tractor, a 7060 to be specific. If one reads the Owners Manual, it tells how to go about this procedure. It has you using all four pusher screws in both bushings. Don't take my advice, look in the Owners Manual. Many times only two of the screws are needed on the non-keyed bushing, but there are some of those times when all four are required to get things busted loose.  Like I said, I think the Engineers learned something from the 210/220 and knew they sometimes needed to be applying pressure to both bushings, not one.
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 7:52am
The information I have came from Allis Chalmers service publication.  7030 Thru 7080 dated Nov. 1975 and the procedure with two jack bolts likewise.  I continue to not know how jack bolts can be used in bushing flange holes that are not tapped ???? I have a feeling that this issue / discussion is more  about the size of your head than about sharing information or helping each other.  THEREFORE I"M DONE WITH YOU.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 8:23am
They can't be used in bushings that aren't tapped. Those bushings you are looking at must be from a 210/220 era tractor and the keyed bushings weren't tapped and the other bushing was tapped in all three holes. The 7000 series has a different p/n for the bushings and (as far as I know) were always tapped in both bushings only the outside two holes, therefore the need for using four jack screws. I suppose there is a chance that tractors have had bushings changed over the years and the parts may not be correct for the model tractor they are on ??  There's also a chance that the publication you read is in error, not being updated to the newer 4 pusher bolt design.  People come on this site all the time asking for help and advice. Incorrect advice doesn't help them and can make things even worse.  No one is blaming you for intentionally and deliberately giving incorrect advice. There is supposed to be a difference between the 210/220 era wheel bushings and the 7000 series bushings and the number of pusher bolts that are used. Accept that as fact instead of being angry.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 5:37pm
DUDE, you might mean well with your (up until now) replies,but you are stepping on some very descent toes and I am pretty sure you 2 are NOT dancing !! Please reign it back a notch or 2, JMO.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 9:43pm
Ok guys. When I made the suggestion near the beginning of this thread that they should have included four instead of three pusher bolts, it was because of my experience with an 8550 and both wedges were threaded. My 220 fwd is next so I will likely find only threaded holes in one wedge so will only be able to use three pushers. I have NOT read any of the service books regarding this procedure. Remember that the pushers push the cast center off the wedges. I can see why A-C made the change.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2018 at 10:44pm
Well, it took John Deere till the 55 series to figure out that its easier to push the wheel off the wedges than to try and push one wedge out by itself.
8070220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070220 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 10:22am
Any one still need them I got a set of 3 here still in the agco bag I sell and I think I got one that is not in the bag PM me if u need a set I have some 190 to .
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 2:49pm
Originally posted by littlemarv littlemarv wrote:
Someone needs to make a video demonstrating whatever in the hell you guys are trying to do
Best post of the hole blamed thread! Star
Wink
I am a Russian Bot
ABDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ABDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 3:01pm
That's what happened in my case. Both large casting were pushed off the wedges. However, I used the four jack bolt method so the casting didn't have a choice.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 3:38pm
I still remember the year we went from 36" rows down to 30" rows. On our 7/8000 series tractors, we would have had a mess if we had tried to use just two jack bolts, as it was bad enough with using four. Got to go with the Doc on this one.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 5:37pm
Ok, back when I first got my big Allis, I got the advice on how to move the wheels on a different forum. Torque the jack bolts, whack end of axle a few times, repeat. No mention of axle whacking in this conversation! For me, a 7045 and 2 jack bolts (pretty sure? Maybe 3?). Only 1 of the split bushings in either case...And the left wheel moved with GREAT difficulty! But with perseverance it came loose.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 6:25pm
I am not going to take sides here, because using two jack bolts and using four can both be right ways to do it. One of the first jobs I got assigned to when I first started working in the shop at a farm equipment dealership was a three way tire swap involving 8000 series tractors; all brand new. For simplicity we'll call the tractors A, B , and C. Rear wheels (cast centers and all) from tractor A went onto tractor B, B to C, and C to A. Don't remember the fine details, but all were FWA, and some front wheels may have been changed, too. It came down to the particular size tire that one customer wanted, and still having matching ratios between front and rear. I had never done the job in my life, much less even had a clue how to. Bosses instructions were to put the keyway up, pull the bolts out of the bottom wedge, and use the special bolts, as he called them (the jack bolts) to push the bottom wedge out. With air impacts and having two small forklifts to handle the wheels, the whole job went off without a snag. Never took a single keyed wedge out. BUT.....everything was BRAND NEW! I've never had to do the job on a 7 or 8 thousand series since, but I have no doubt that years of rust could change the whole scope of things. If I had to do the job again, long before I would put enough torque on a jack bolt to break an ear off, I would use four bolts on both wedges. I have removed wheel centers several times on D19/one ninety and XT tractors that have much age on them, and have never had an issue. I ALWAYS clean the jack bolt hole threads with a tap, brake parts cleaner, and compressed air until they are about flawless. Then I use grease, not oil, on the threads in the hole and on the jack bolt, plus I grease the pointed tip of the jack bolt. Go from bolt to bolt with the air impact and just chatter a little on each one, and never had one put up much of a fight. Guess when I get back to doing 7 or 8 thousand series ones again, I'll use the "clean and grease" method and try getting out JUST the non-keyed wedge. But as I stated previously, long before I am putting enough pressure on to bust off an ear, I'll use four jack bolts and take out both wedges.
Now, put the gloves away and let's all get along. We can't afford to lose ANY members off of this forum. Any and all advice from everyone is necessary to keep the old allis spirit alive. Darrel
leoversteeg11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 6:30pm
My 7030, 7080,8070, both wedges are tapped and we used 4 bolts + lube + sledge +heat every single time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 7:47pm
I did mention the big sledge in my second post last Sunday. I also used a 3/4" drive air impact gun. Didn't have to use heat. I broke the flange off a wedge on a 4250 JD years ago. Talked to the service manager at the dealership and he said to use a big sledge and hit the end of the axle as hard as you can after you have full torque on the pusher bolts.
I think that made the difference between getting the centers off the 8550 or not getting them off. Sledge hit, re-torque, sledge hit , re-torque. All of a sudden the center starts moving. One made a pop sound after I walked away and then off it came. Big sledge is a very important part of the procedure.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2018 at 10:20pm
We always use antiseize on the every thing before putting back together when moving hubs on our Allis and JD tractors. We have never had any trouble with moving after that.
rieg
This page was generated in 0.220 seconds.
