7060 hydraulics |
deltaallis ![]() Bronze Level ![]() ![]() Joined: 03 Mar 2012 Location: Tennessee Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Apr 2012 at 11:35am |
I am looking at a 7060 for purchase. After talking to the seller I understand the power steering works but the remotes and 3 point do not. Am I looking at a replacement of the entire hydraulic pump? Or is there something else that might remedy the situation. If it is the entire pump what am I looking at cost wise and where can I find one? Would anyone recommend one from a salvage tractor?
thanks; and any help is much appreciated.
Trying to give credibility to orange in the deep south where everything is red and green.
Lester ![]() Orange Level ![]() Joined: 08 Jan 2010 Location: Indiana Points: 521 |
There is a good chance that your hydraulic valves are stuck. They were all stuck on my 7020 high crop. Took them apart and sprayed penetrating oil on it and they started working on the 3ph and remotes.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21848 |
I'd wager a broken spring on the low pressure spool on the main hydraulic pump compensator, or it needs to be shimmed to get stand-by pressures back up to 400 to 600 psi (that's where I set them). Could also be a broken swash plate spring inside the main pump. Either are a very easy fix for a trained tech and inexpensive. Another clue to this problem would be the PTO lever won't stay engaged by itself and the brakes are poor.
Thanks guys;
That will help me in my decision to buy
