7060 hydraulics |
spencefarm ![]() Orange Level ![]() Joined: 29 Apr 2013 Location: Fairbury IL Points: 349 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Dec 2015 at 4:37pm |
So I have a 7060 and when I was field cultivating last month all of a sudden hydraulic oil started spraying from the back of the tractor. I lost all pressure and I can't find the leak. So I need some advice....
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Refill and find another set of eyes. Took my dad and I 20 minutes to find one on his combine a couple years ago.
AaronSEIA |
The pump had been whining a bit before that. Is it probably just a busted line or could it be the pump went out?
Hyd. pump is not on back of tractor. Line most likely. MACK
JPG AUSTRALIA ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 767 |
Theres a steel line that vibrates and wears through the clamp on the left side ,cant remember which one but i have welded mine twice back in the eightys, it is now hydrulic hose instead and hasnt given any trouble since.
