7045 vs 7060 differences |
AllisHunter ![]() Bronze Level ![]() ![]() Joined: 13 Jul 2020 Location: Missouri Points: 40 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Dec 2020 at 6:33pm |
Hey everyone, I just bought a 7045 that needs a rebuilt motor. I’ve heard that 7060s are very similar. What are the main mechanical differences between the two? I don’t want to necessarily have the power set at 7060 levels, I just didn’t know if there were any parts from a 7060 that would benefit a 7045? I’ve heard that 7045s can run hot? Thanks
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22080 |
Tractor chassis is identical, as long as the same age for both. 7060 has an intercooler and a larger radiator and fuel setting for 160 HP.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
7060 has an intercooler. Not sure if the fan is bigger or the radiator.
Wink I am a Russian Bot |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12236 |
I suggest either sticking a good 7060 radiator in it, or have the one you have recored with an additional row. The recore option is what I did, and is equivalent to the 7060 radiator. You’ll have no problem with running hot like that as long as you have good foam and keep things clean once in a while.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Well said!!
