7040 injector pump
jdswmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdswmo Quote  Post ReplyReply Direct Link To This Post Topic: 7040 injector pump
    Posted: 03 Jan 2011 at 6:38pm
Will the injector pump off a red belly 7060 be the same as black belly 7040?
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 7:09pm
they never made a black belly 7040 so someone has painted it, the pump will work ,the settings are different, but not anything that will cause a big issue
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 7:45pm
It will bolt right up.  It will probably put out more fuel than what your 7040 is used to, so you will probably get a HP boost, but you will probably burn more diesel also.  Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdswmo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 7:13am
My book says the timing is different so I didn't know if it would be the same pump.
       Thanks    Jim
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 9:21am
It is the same pump, but I would take it in and have it calibrated for the 7040. As far as the timing, that is done when the injection pump is installed.
Edited by bigal121892 - 04 Jan 2011 at 9:22am
