7030 Block Heater |
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 376 |
Topic: 7030 Block HeaterPosted: 1 hour 55 minutes ago at 4:24am |
I decided to put a block heater in my 7030 in case it is needed this winter. It has had a combine engine put in it so it doesn't have one now. I don't know a lot of history on the tractor so I plan to change out the coolant at the same time. The question I thought of is what are the chances of the plug coming out clean after 50 years? And then is there a good way to repair the threads in the aluminum casting? Thanks in advance.
![]() Ted |
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
