7020 power shift operation/ engine mains/rods
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Topic: 7020 power shift operation/ engine mains/rods
    Posted: 15 Dec 2016 at 6:49pm
the tractor has a high/low/ park position,  then a tee handle with 6 speed how does it shift?  this is a power shift?
was there also a need to replace the main or rod bolts on the engine because they loosen-up?
dan
Edited by Acdiesel - 15 Dec 2016 at 7:34pm
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 7:56pm
You have the power director, the only on the go shifting is the button I the floor you hit with your foot. Have a 7045 with same tranny and when taking off from park I take the park lever forward into neutral then go to the T handle and put it in the gear you want then go back to the other handle and put it in fast or slow range. I used to struggle shifting it but that sequence works for me everytime.
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 8:36pm
7020 has a 301.The 426 is the one with rod bolt issues,depending on who you talk to.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 10:06pm
The "t" twists it does not move side to side. The arrows will point to the gear it will be in depending if you move the t handle forward or backward. It will only twist in the neutral position.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 10:23pm
If it has 5000 hours, it needs new rod and main bearings.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 6:01am
THANKS!
IT HAS THE 649I (301) ENGINE
 3456 ORGINAL HOURS AND OWNER.
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
This page was generated in 0.254 seconds.
