7020 power director transmission brake.
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Topic: 7020 power director transmission brake.
    Posted: 13 Apr 2019 at 6:41pm
So I’m having some transmission brake problems. The clutch and brake were replaced at a dealership about 400 hours ago. The bushing in the lever on the housing were replaced then also. The brake doesn’t work at idle except right after cold start. It will work at 1800 rpm. I do have a new clutch cable that I will try but if this fails to correct this where should I go? I am also noticing some whining at the steering orbital when the rpm is up.
This page was generated in 0.349 seconds.
