7020 Injection Pump
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Injection Pump
    Posted: 12 Apr 2019 at 10:22am
How can I tell if my pump has been turned up? It smokes a some but not a lot. I don't use all the horsepower and I would like have it turned down a little so it don't use so much fuel.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 10:29am
Smoke can be caused by using truck stop/ convience store diesel fuel instead of premium #2 diesel fuel. Your tractor was designed to use premium #2 fuel. Black smoke is unburned diesel fuel going up the stack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 12:17pm
L
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 12:21pm
Originally posted by Jack(Ky) Jack(Ky) wrote:
L
I know that. I use off road farm diesel.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:22pm
Be hard to tell unless you put it on test stand. I thought they all smoked.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 9:47pm
If you take your 7020 tractor (rated at 120 HP max) and use it on a load that only requires the governor to demand 50 HP output from the engine, turning the fuel delivery down to produce a max of say 100 HP will show zero fuel savings on the same load. What you think you want to do really doesn't work like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 5:42am
Thank you guys for the info!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 6:23pm
Put it on a dyno
Wink
I am a Russian Bot
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 6:56pm
You are packing 12,000 + pounds... lighten it up will save hp/fuel if it is weighted --- it is not an economy tractor as it takes hp to move that weight.
