7010 engine overhaul |
HagerAC
Topic: 7010 engine overhaulPosted: 9 hours 23 minutes ago at 10:52am |
My open station 7010 started dripping coolant out of the breather this summer and parked it after I noticed it. I'm not sure when it started but it wasn't this way when I had the valve cover off late last winter and have only put less than 10 hours on it in the spring Have since dug into it and found a leak coming from between the number 6 sleeve and block. It is tired and needs a freshening up anyway. Wondering about what kit to use. I did put an Absolute kit in my 190xt a few years ago and have been happy with it. Seemed like a good kit and would probably go that way again. I have also found a kit from Federal Power Products, wondering if anybody had any experience with this kit or not? I am not interested in a Reliance kit. Thanks
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3542 |
Posted: 4 hours 24 minutes ago at 3:51pm |
Sounds like you need block work more than an engine kit. I would check sleeves for roundness and re ring if ok - you will have to do a close inspection to determine what is needed - you are going to have to spend the money sleeving the block bottom bores quite possibly and by all means re-bearing all.
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2206 |
Posted: 4 hours 15 minutes ago at 4:00pm |
We rebuilt a 301 in our 200 January 2024. Used a Reliance kit from Agkits. Bought the gasket set from Agco. We were satisfied with the Reliance kit. Tractor starts and runs perfect. Gonna split an XT tomorrow for a rebuild. Plan to do it the same way. Sorry I couldn't be more helpful.
Leon B Mo |
Posted: 2 hours 14 minutes ago at 6:01pm |
For best results, remove the oil pan FIRST and pressurize the cooling system to 100% absitively determine where the leak(s) are coming from before you rip it all apart.
SilverShoes
Joined: 20 Feb 2014 Location: Seneca, Kansas Points: 175 |
Posted: 36 minutes ago at 7:39pm |
I replaced my 7010 head because it had cracks around the injector sleeves. I used a 200 head because they didn’t have sleeved injectors. Could your leak be coming from the injector sleeves or head cracks?
