7010 AC Part ID?? |
Roscoe62
Joined: 22 Aug 2014 Location: Louisville Points: 145 |
Topic: 7010 AC Part ID??Posted: 16 Mar 2017 at 4:13am |
Below are photos of a ?fuse? that is clipped to the block just in front of the coolant filter on my 7010. I must have bumped it when replacing the filter recently.
What is this? The wire runs up to the air conditioning compressor. What do I look for when trying to find a new one? Thanks, Roscoe ![]() |
Roscoe62
Posted: 16 Mar 2017 at 4:16am |
Second photo:
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2438 |
Posted: 16 Mar 2017 at 7:16am |
It's a GM air conditioning fuse or sometimes called a thermal limiter. Any automotive parts store should have that.
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 16 Mar 2017 at 7:17am |
i think that's whats left of the thermal limiter fuse for the air conditioning system!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
MACK
Posted: 16 Mar 2017 at 7:18am |
Just ask for a GM air conditioner fuse or take it off and bypass it. MACK
farmboy520
Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Posted: 16 Mar 2017 at 7:39am |
I agree with the bypassing
Roscoe62
Posted: 16 Mar 2017 at 8:57am |
So just stick a jumper wire in the two outside slots?
Thanks! What is a thermal limiter supposed to do, anyway? |
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 16 Mar 2017 at 11:16am |
Stolen from the internet, cause I am too lazy to type....... A thermal limiter is much like a fuse. This device was used on many General Motors cars and trucks during the mid to late 1970s and was designed to help protect the compressor inside the air conditioner. The thermal limiter switch keeps the clutch in the air conditioner from engaging when the air conditioning system is low in refrigerant. The superheat switch sends the information to the thermal limiter switch to prevent the clutch from engaging. When refrigerant levels in the air conditioning system are too low, the evaporator within the system will be forced into superheat conditions. This simply means that the vapor from the refrigerant in the system’s evaporator will become overheated. When the superheat switch, which is located in the rear head of the air conditioner’s compressor, gets the signal that the evaporator is being overheated, it will send the message to the thermal limiter switch which will in turn completely shut down the air conditioning system within the vehicle. This is done to prevent damage or failure of the system.
Still in use:
Roscoe62
Posted: 16 Mar 2017 at 11:19am |
Thanks!
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3546 |
Posted: 16 Mar 2017 at 8:38pm |
a words of caution - if the coil on the compressor clutch is drawing too many amps it will blow the fuse,,, by passing it will eventually melt the harness..// check the amp draw on the coil - should not be over 5-6 amps. country boy way to check is take a 12v powered wire and touch it to the coil wire with a 5 amp fuse in-between - should not blow fuse.
