7000 engine
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 engine
    Posted: 10 May 2010 at 8:08pm
What size is a 7000 Allis engine? A 4 cylinder diesel, turbocharged, looks to be an SAE flywheel housing. Was it used in anything ag?
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:20pm
7000 has a 301 cubic inch 6 cylinder turbocharged engine. A 4 cylinder turbo engine would have been in a 6080 or on a combine.
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 9:41pm
The model 7000 engine is a 4 cyl, 4.56 bore x 5.62 stroke = 344 cu.in. max hp. 150 used by const. in T-16, TL-16, HD6AG, 7G, M70. It was turboed.  Sam T-Ga.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 10:06pm
So, that is a pretty big engine, bigger than a 4-53 Detroit or 4BT Cummins. Several for auction at Ft. Carson.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 10:17pm
Very confusing that a company would use the same model number on a tractor and an engine!
iescdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iescdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 1:22pm
Dseries4 you are absolutely correct about it being confusing that an engine manufacturer and a tractor manufacturer uses the same model number. These type of issues arise all the time in the diesel engine rebuilding world and we here at IESC DIESEL, CORP. are here to simplify eveything. We are able to cost effectively facilitate the diesel engine rebuild identification and parts sourcing process which translates to great pricing and customer support for you the tractor/truck owner.   Feel free to post any questions you may have to this thread and I will try my best to have an answer/solution for you as quickly as possible.
Alejandro Paret / VP of Sales & Marketing
IESC Diesel
alex@detroitdieselmiami.com
888-MIAMI
60  (888-642-6460)
O: 305.470.9306
F: 305.575.2834
C: 305.796.6078
www.detroitdieselmiami.com
Edited by iescdiesel - 29 Jun 2010 at 1:23pm
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 7:11pm
I have a power unit Mod 426 4cyl "Made in Japan for Allis chalmers."  Have not had the need to open it up and see what it really is.....Dale
sehappraiser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sehappraiser Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 12:54pm
I have a 1978 Dodge W200 with a 4 cylinder turbocharged Allis engine from an experimental cotton stripper.  I put about 20000 miles on it.  the engine needs overhauled now, broken rod?, I have not looked inside yet.  What does an
overhaul kit cost?  Or I will sell it for ???
With the 4:10 axles and the 3 speed automatic it will max out at about 61mph @ 2800 rpm.  Bell housing adapter was from Zealand MI and mounting rails were locally built.
mahto48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahto48 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2013 at 12:32pm
I have an HD 344 buda in my Hd6E. I would like to replace it with a 7000 series 344 cubic Inch. Does anyone have information on this swap. The engine blocks look identical. Just different attachments, diesel pump, head, Bellhousing,front engine cover etc. Can anyone help me with this.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2013 at 12:06am
I believe it is the 516 buda cut down 2 cylinders.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2013 at 7:56am
I always heard the 344 didn't like higher rpm but Dad's HD11 with 516 has been a great dozer and easy on fuel and starts like a dream unlike most Allis engines I've been around.
Wink
I am a Russian Bot
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2013 at 10:58pm
If any one needs parts or complete engins for 516 give me a call. 660 828 4310   MACK
Bcrichardsonusmc2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bcrichardsonusmc2004 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 11:31pm
Don't know much but I'm looking for a 344 buda engine or something to repo were my hd6 crawler with any sugestions?
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:20pm
Might have been the same company, but two totally different divisions. Heck, my brother and I don't always know what the other ones doing, can't imagine it being much better in a big company.
