6080 injector pump |
mapleview ![]() Bronze Level ![]() ![]() Joined: 18 Sep 2017 Location: Upastate NY Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Sep 2017 at 9:11pm |
I have a 6080 that will not rev over 1100 rpms and will stall at idle. I am suspecting the injector pump. Any help would be appreciated. Thanks.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22021 |
You start by disconnecting the fuel supply line from the tank at the fuel filter base and see if there is a gushing stream of fuel coming to the filter. If not, you probably have a plugged fuel tank outlet.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5110 |
If fuel supply proves good, loosen the pump timing cover on side of pump, and see if it runs properly while letting the fuel leak out that side cover.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8648 |
....and if it does...send it to Ed cause the flex ring is leaving....
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3538 |
there is a plastic bleed screw on the back of the pump = loosen it while the unit is running - it should still run fuel out while the tractor is running - if it dies - see Dr,s post...
