6080 hydraulic filter o-rings
ksucat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksucat Quote  Post ReplyReply Direct Link To This Post Topic: 6080 hydraulic filter o-rings
    Posted: Yesterday at 10:27am
Drained fluid and replaced filters on my new-to-me 6080 yesterday. One new filter (WIX 51831) was fine. O-rings for the second filter(WIX 51652) don’t have a good place to go. Both that came with the filter are larger diameter but thinner than the o-ring on the old filter, so I’m not getting a good seal. Did I get the wrong o-rings with this filter or am I missing a trick to hold them in place?
Thanks
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:00pm
Are you speaking of the longer filter?   You might need to try a second O-ring maybe or a different one.   The new filters aren't providing a good o-ring anymore and might be made slightly wrong.  At least that is my guess from when I had the same problem on a 6070.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksucat Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:14pm
The Agco parts book shows the o-ring as a separate part from the filter, and only one ting between the filter and housing. Looks like I reuse the ring off the old filter and toss rings that came with the new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 40 minutes ago at 7:37am
Do you have suction filter effective sr#5284.
We don’t have any issues with agco filters 70270958. It comes with multiple orings but only one is the correct one. Other doesn’t do anything.
Other hyd filter is 70253952
We have both agco filters available
Edited by Mikez - 9 hours 37 minutes ago at 7:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksucat Quote  Post ReplyReply Direct Link To This Post Posted: 12 minutes ago at 5:05pm
Yes, this is the suction filter. Looks like I’ll go with agco next time. Rings with the wix didn’t work, ring from the old filter is in place and doing its job.
