6080 draw bar
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 draw bar
    Posted: 21 Apr 2012 at 1:02pm
I need a different draw bar for the 6080 I bought a year ago. I need the thicker one that was on the later ones. Part number is 72094177 and is 1.687" thick. We hauled manure with it this year and some of the loads made the thin one bend pretty far. Any help would be a appreciated. Thanks, rrhead(SD)
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:41pm
Get a salvage one - I got my latest from Heitman tractor.  Bought  an aftermarket one from Wortington 5 -6 years ago and didn't take long to bend it bad.  Unless you change stuff around under the tractor you can't just switch to the thicker one.
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 8:32am
I got one for mine from our AGCO dealer but they sourced it from A&I. 200 to 250 if I remember correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 8:55am
Thanks for the replies. I will have to get the 6080's side by side and compare. Did not check under tractor. Looked like it would fit through the back holder. rrhead(SD)
