6080 Brake Oil Level Light
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Brake Oil Level Light
    Posted: 09 Aug 2026 at 2:35pm
Yesterday when I got my 6080 started, the brake oil level light stayed on.  I've been looking for an original manual, but not yet been able to come across one to look this up.  Can anyone help as to why this light remains on?  If brake fluid is required, where do I add it at?  As an FYI, the battery was dead and I had to jump start the tractor.  Don't know if that is pertinent to the brake light issue, but mention it.  Thanks, Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2026 at 4:11pm
it takes hydraulic fluid, not brake fluid... left side of firewall... watch this movie..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 8:28am
Wow, thanks.  Good video.  So I'll use the universal transmission/hydraulic fluid to fill it.  Dave
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 10:36pm
Not hydraulic oil either. Not sure exactly what is recommended but not 821
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 10:47pm
some use Dextron or Type A transmission fluid as it is a 10 wt oil.... Many will use hydraulic/ trans fluid like 821... you just down want a 30 wt oil... Thin is good..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 6:32am
Disappearance of this brake fluid oil is an indication that the brake piston seals inside the rear axle housing are leaking. After 40+ years, this ain't the first time that has happened. So, you deal with the leakage until you can't stand it anymore.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 7:17am
technically you want 10w-10 oil as others said behind fire wall.  Check your electrical connections first.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 7:14am
AGCO and NH both make a brake fluid designed for these as well, as they use the same Fiat rear end.  As them for the mineral oil brake fluid.  You can also find it labeled as LHM fluid.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2026 at 8:41am
Well, got the new battery in.  Added a minute amount of fluid.  Started right up and brake light not on, so assume it is all good.  Still not sure what fluid is right to use, but put in such a small amount, not going to worry about it, I guess.  Thanks for the comments.  Dave
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 6:50am
The light on mine would flicker, drove me nuts. Had the loader off so removed the panel, put in about a tablespoon of oil, problem solved.
Joe D15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe D15 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2026 at 12:38pm
I know that I had issues with the brake light on my 6080 when I got it. If flickered a bit and I looked into the proper fluid to add. I added fluid to bring it up to the line on the side and the light went out.
While I had the top off, I noticed that the float didn't freely move up and down. The contacts on the float wouldn't always complete the circuit. Lately, I've had the light come on now and again. I am going to look more into the level and how to make the float switch work properly.
Joe
Dad's '52 CA, '68 170
My '61 D15, '85 6080
Was Joe in Manty
