6060, 6070 and 6080 |
BV
Joined: 12 Sep 2009 Location: Bono Arkansas Points: 489 |
Topic: 6060, 6070 and 6080Posted: Yesterday at 1:59pm |
which FIAT tractors used these transmission and rearends as the A-C tractors and can you still get parts for these? how good were these tractors and was one better than the other, I had a F2 Gleaner with the little 4 cylinder engine and it ran good and had plenty of power.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7589 |
Posted: Yesterday at 3:38pm |
6060 Used the Fiat 780 transmission. 6070 and 6080 Used the Fiat 980 transmission. Some Ford/New Holland tractors also used the same transmission and rear end, so parts should not be a problem. Haven't had to touch my 6080 , but it's a great tractor. Mine dynos at 108 hp.
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 585 |
Posted: Yesterday at 3:58pm |
My 6060 has about 3300 original hours and has a 460 loader on it - a great, nice handling tractor!
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3574 |
Posted: Yesterday at 4:20pm |
A couple of the Hesston tractors had a transmission common with the 6080 as well. The last batch of parts, well they thought a lot of them. One would think as many as they are around the world someone in the aftermarket would pick up on them a they have others.
BV
Posted: Yesterday at 4:43pm |
I don't know how they get so much power from that little engine, I was reading about the PTO affecting the thrust bearing in the engine and the bra bearing being added to the front of the engine, does any of you guys tractors have this added front bearing or did they correct this problem? Was this potential issue noted in the operators manual and just overlooked by the operator? Another thing I noticed was the two tractors I was looking at for sale the rear axle seals were leaking, was this a problem with them or just a coincidence with the ones I looked at? Was one better than the other between the 6060,6070 and 6080? Thanks for the information. I wish I had a nice 175 with the 433 A-C engine installed.
DSeries4
Posted: 2 hours 43 minutes ago at 2:16pm |
The newest models did not have the "bra" on the front of the engines - Mine is a mid 1985 and it does not have it. I think there was a certain engine serial number where the block was reinforced to solve the problem - I can't remember the number though. Leaking rear seals? Possible? Of course. A common problem? Maybe. You got to remember that you are looking at tractors that are over 40 years old. Leaks are to be expected. The 433 is a great engine. However, below 1500 rpm it can fall on its face with a load. Keep it above 1500 and you won't kill it! The guy that did the dyno test on mine couldn't believe it. Just kept pulling!
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1551 |
Posted: 1 hour 24 minutes ago at 3:35pm |
Myron how do you dyno your tractors. Do you have a PTO dyno in the area or other means to test. I use Fred Smith in Cayuga to test automotive engines for our hotrods. We just take the engine to him. Very neat operation. Impressive to see a small V8 put out near 500 hp at 6600 rpm.
