5020 issues |
Charlie
Joined: 15 Aug 2011 Location: Lapeer, Michiga Points: 2 |
Topic: 5020 issuesPosted: 15 Aug 2011 at 8:02am |
I have a 5020 and is a great tractor but there is an issue with it wanting to over heat. I try and keep the radiator clean but still over heats if pushed. Previous owner took out the thermostat and I'm wondering if that's making it worse.
It also gets a dark oily film on the battery terminals and I have to keep cleaning them so it will start. Any ideas to fix these problems?
john(MI)
Posted: 15 Aug 2011 at 1:18pm |
I just had the battery problem. Was caused by the ground cable, loose connection.
The overheating may be caused by the rad being plugged. I had mine off when I changed the water pump, and it took me about two hours to get it washed out! Runs lots cooler now.
nsula_country
Joined: 10 Mar 2011 Location: NW Louisiana Points: 218 |
Posted: 15 Aug 2011 at 2:52pm |
Sounds like you need to take your radiator to a good shop and have it rodded out. My Komatsu excavator was doing that last year. Cost $60 to have them boil it out and rod. Cheaper than scorching an engine.
CT
