4th Gear in a 180 |
KevinON ![]() Orange Level ![]() Joined: 07 Dec 2009 Location: Schomberg, ON Points: 801 |
![]() ![]() ![]() ![]() ![]() Posted: 14 hours 57 minutes ago at 7:21am |
Just wondering if anyone could tell me what the tooth count should be on 4th gear (input shaft) on a 180/185? I have two transmissions, and one gear has 36 teeth and the other gear has 42 teeth. Thanks.
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3483 |
70256571 19 tooth with 15 coupling teeth. The only one I know of on a 180
70245780 20 tooth 20 coupling - first 190 70245722 19 tooth 70246407 19 with 12 coupling look on the input gear to see if there is a snap ring groove cut in - if so it is a D series.
Edited by tbran - 11 hours 39 minutes ago at 10:39am |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21409 |
If you have 36 and 42 teeth on the input shaft to the transmission (direct drive/4th gear) it is custom made. They are usually two parts: a gear (36 or 42) and an input shaft with splines and a snap ring groove to hold on the gear on those splines. A gear that large will not fit thru the input shaft bearing hole in the trans case. A gear that large is assembled from the rear being slid onto the input shaft while the shaft is being installed into the trans case from the front.
I’m trying to attach a photo of the gear, but the file size is too big
