460 loader control valve options |
farmtechguy
Joined: Yesterday Location: United States Points: 3 |
Topic: 460 loader control valve optionsPosted: Yesterday at 10:36am |
Greetings, I acquired a 160 diesel with (I believe) an OEM 460 loader the other day. After using the loader a bit it's apparent I have an internal hydraulic leak as the bucket slowly sinks with a load in it. I'm inclined to think it's in the control valve. When I go to lift the bucket, if I only open the valve ever so slightly, the loader drops. Once I open the valve enough, it lifts just fine. My question is: couldn't I just replace the valve with a cheaper universal spool valve from ebay? I'm sure the cylinders could use a seal job as well. Your input is much appreciated!
Edited by farmtechguy - Yesterday at 10:38am |
ac160
Thanks(1)
Posted: Yesterday at 11:29am |
Try changing the packing in the cylinders first. I have a 460 loader on a 6070 that leaked down with or without a load, and new packing solved that issue. There were two versions of the 460 loader, one for a 160 and the other for the 6060 - 6080.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4800 |
Thanks(1)
Posted: Yesterday at 1:08pm |
I would agree start with the cylinders first. But there is a no tools required way to check. When you first start the tractor run the loader up and let it leak down a number of times. As it is lowering put your hand on it, the bypassing oil will create heat. If you cannot feel any warming of the cylinder, then the valve is your leak.
farmtechguy
Posted: Yesterday at 1:53pm |
Thanks for the replies. I picked up a 4x5 round bale and definitely have gland seal leaks on two of the cylinders. I'll do the test you describe here in a little bit and report back. Do you guys think an internal cylinder leak could be the cause of the "dead" spot when opening the control valves? It's pretty bad when I it loaded up.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3124 |
Posted: 12 hours 17 minutes ago at 9:00am |
I'm having a similar problem with a tractor and loader I recently bought.Except the loader doesn't leak down when sitting but when in use when a I pull the lever to raise the loader it'll drop some before it starts to go up.I'm thinking its the valve but maybe not.Taking it to a shop near Harrisonburg VA they are very good on hydraulics.
