433i
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: 433i
    Posted: 19 Sep 2011 at 8:20pm
what is the bore spacing and the width and length of the deck? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 3:25pm
bump 433 allis chalmers engine out of a combine?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 8:39pm
1-2-3 sme as 301 and 3-4 will be same as 3-4 on 301.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 4:52pm
MACK do you think it would fit in a wd?   is they a series of it better than another. when looking for one to purchase
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 4:54pm
IG has one (433I), a shame, it used to be in TN!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 5:20pm
anyone hot roding one you know of
Debbie7562 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Debbie7562 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 8:10pm
we are getting ready to put one in a d15 for next season in a new a light hot class 4000 rpm max and one turbo and no speed limit 3500 lbs
My pulling tractor! WD stands for, You have just been beaten by a Woman Driver!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 8:47pm
i am a non speed limited non turbo guy but wondering about hilborn alcohol injection and some extra bore and stroke .thinking the 80 hp block may be stronger than the 226 block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 9:01pm
Waaaaaay stronger than a G-226 block and has five main brgs to boot.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 9:28pm
I would think it would be hard to clean after at 3500 lb.  The wd45 would better than a D15 for the transplant. D15 has tooo many weak places for that HP. Trans, pinion, and final drives.
  The 45 has some weak places, but they can be taken care of much easier than a 15.   Good luck and hope the best in your endivers.
 If I can be of any help on the weak parts let me know.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 9:26am
MACK I need a set of d 19 gas rods flame hardened . Can you help with that after talking with you I think that's been my rod issues. The head on the 433 is a cross flow right? Does it have four individual intake ports?
Mack and Dr.Allis  how much hp do you think one of these engines can produce ?
Mine if I build one will be normally aspirated alcohol injected with some extra stroke and bore if its do able. I am hoping I can use the injector holes for spark plugs.  I really need one purchased to check it out further if anyone knows of one forsale
Edited by mlpankey - 23 Sep 2011 at 9:33am
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 10:17am
The 433 head is crossflow but has only 2 intake and 2 exhaust ports.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 10:35am
dang the luck is the head bolt pattern and engine deck about the size of a 4035 deere block?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 9:03pm
I think I have 6 heat treated rods. They will be 35-40 rockwell hard.
  Don.t know how hp you can get without a turbo and on alc, but I've seen them stock with only pump turned up and stock rpm make 115 on dino.  MACK
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 5:45am
You need to find an engine out of an H-4 crawler. It is the gas version of the 2200 series engine which later became the 433. I don't know anything about them except that they exist. I don't know of any other application for the gas version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 8:10am
Dear Debbie 7562:   Take Mack's advice...don't use a D15 chassis. I've seen them with teeth off of the ring&pinion with 46 hp....I can only imagine what a 433I engine would do to them tiny teeney weeney gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 10:18am
give me a call mack on those rods at your convienance 423-242-8596 verizion .
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 1:05pm
Have a 433 engine, less crank. Have everything else, block, head, turbo, inj pump etc
563 652-2949
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 2:02pm
You need a model 7000 AC 344 engine, 4 7/16 bore X 5 9/16 stroke 4 cylinder diesel with a big 8 port head.  It was used in the AC T-16 tractors.
Lots of these engines available as power units from gov liquidation auctions
Edited by Rod B - 24 Sep 2011 at 2:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 9:25am
whats the weight of this engine with the 8 port head
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 12:48pm
Bore spaceing on a 433 is the same as a 301  1 and 2 are togather, 3 and 4 togather and a large gap from cylinder 2 to 3 as Mack pointed out.   The gas head flows real well from the 301 gas engines and will bolt on if cut off.  The diesel head does not and is cast in a way that it is undesireable.  By moveing cyl 2 and 3 togather and 1 and 4 out, one can get a 4.6 bore in these engines.  Removeing the oil pump will allow for over a 5" stroke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 12:53pm
The 344 is a heavy engine at 1200 pounds when we took it apart.  The engine alone is about 600-700 pounds  for the long block as a guess.  All the accesories on it are quite heavy large cast timeing cover, flywheel and housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 5:43pm
Thanks  Rod B good info.
