3-Point Arms Stuck?
Derricks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Topic: 3-Point Arms Stuck?
    Posted: 2 hours 7 minutes ago at 4:27pm
I've got a D17 Series IV that's got 3-point arms that don't want to move.
All of the levers are moving (I sprayed some lubricant to really free them), and some will make some noises...but the 3-point arms don't want to move.
I believe I'm supposed to put both of the rear levers (traction control) to the forward position, then the farthest right lever in the front (set of 3) is the one that should control the 3-point arms (up and down). I move that lever forward and back while stepping/jumping on the 3-point arms and they aren't moving.
Any ideas?
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 57 minutes ago at 5:37pm
Believe the short lever on the left is to go foward
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 55 minutes ago at 5:39pm
Believe the short lever on the left is to go foward, position control. And ya got to force the arms down.
Edited by whatscooking - 54 minutes ago at 5:40pm
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 39 minutes ago at 5:55pm
What does the operators manual say? You may have the levers moving but not the valve spool itself.
