37 wc budget build puller |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3731 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Mar 2025 at 4:11pm |
![]() ![]() ![]() ![]() Edited by HudCo - 16 Mar 2025 at 8:33pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21236 |
The D-19 carbs I have used in the past (Marvel-Schebler, not Zenith) I drilled out the seat of the needle and seat. This is because gravity fuel flow from the tank sometimes couldn't keep up when running 2500 RPM on a 300 ft track. So, be prepared if you run fine up until the end and it seems like it might be running out of gas
i believe thats the very first brand new tractor carb i have had , its big old girl it clears the block by 1/8 will start updating pictures
Phil48ACWC ![]() Silver Level ![]() ![]() Joined: 17 Jan 2013 Location: Vermont Points: 296 |
I have a WD-45 Crank I would sell. $300 plus shipping.
have had a new 45 crank in the box for about 4years , i am useing a d17 series 4 engine that i got from the scrapper after the claw destroyed the rest of the tractor
Be sure to mark the flywheel for 15-20-25 degrees. The Fire mark is 30 degrees BTDC. 15 is half-way between fire and TDC. You'll figgure it out.
hitch and wheellie bars almost doneu
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4906 |
Just imagine where your pull point is going to be if by chance the pin at the front of the drawbar were to shear off. When I was a safety inspector for different clubs I discouraged drawbars with that sort of height adjustment. A cradle built around the drawbar with push bolts up and down that will allow the drawbar to slide cleanly our without changing the pull point to a higher position is much safer.
not much to biuld to on that tractor
guess thats what the wheelie bars are for. this is the first puller ive biult and probley the first dedicated puller in my area their isnt much for hitches out on the inernet for hitch or wheelie bars for the wc if it dont work i will do somthing differant . i should be the big fish in a little pond for a while hoping to spark a little more interest around here without spending a zillion
When you find out it is an issue, it will be too late. Just build a support attached the same as the OEM. Then make a provision with push bolts up and down.
I've seen numerous hitches break in the past 50+ years.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4844 |
I always thought I would like to build a set of wheelie bars that could be removed or raised by just pulling one pin on each side, similar to the way a receiver hitch on a pickup truck. The wheelie bars can be a real problem when loading/unloading. Front end goes up and the wheelie bars hit the ground.
Edited by WF owner - 20 Mar 2025 at 5:43am |
the framing square and the tube clamped to it is right at 5 inches beyond the radius of the tire and 10 inch high so if i put my pad on it that will be in the rules i should be able to pull a pin and slide them up and be flush with tires and not be in the way for loading. i am hoping the angle is enought that if you hit the wheelie bars they are skids and not rippers
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3788 |
Hudco, we havnt spoken for awhile. Our conversations regarding flywheels. yes the 45 flywheel does not have the undercut on the clutch side, but it does have less material on the crankshaft side. Have not been able to weigh them but the difference might be closer than we think, and reading you post above confirms that.
Edited by CAL(KS) - 21 Mar 2025 at 10:02am |
wc and wd flywheel but is a wd 45 flywheel any differant ? i dont have one to weight i was supprised that the d17 wheel is lighter with the ring gear, i think it was 58 lb. by the way nice videos
Edited by HudCo - 22 Mar 2025 at 6:25pm |
Kip-Utah ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Southern Utah Points: 881 |
We use two WC flywheels as weights on one of our pullers. One is for a crank starter and the other one has a ring gear. They both weigh 65 pounds.
kip i want to come down south this summer and maybe get a lesson or two at least have a little fun
We’ll have our first pull at the Washington County Fair in Hurricane on April 19 at 10:00. The Cotton Days pull will be a week later on April 26 in Washington, Utah. Then we won’t have another pull until Labor Day weekend at the Iron County Fair in Parowan. Then our best event of the year will be our two-day pull in Cedar City on October 24-25. This is held as part of the Cedar Livestock & Heritage Festival. The pull on Saturday the 25th is unlike anything you can experience anywhere else. We have a draft horse pull & tractor pull on two side-by-side tracks in the same arena at the same time!!! We’d love to have you come down. Kip (435) 592-4045
kip thanks for the chat on the phone the other day
Mike, I enjoyed our visit as well. Gleaner E, 170, 175 are all candidates for the parts you're looking for. Kip
