37 wc budget build puller
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 37 wc budget build puller
    Posted: 16 Mar 2025 at 4:11pm
this  was april two years ago
Edited by HudCo - 16 Mar 2025 at 8:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 4:23pm
working over new manifold for new d19 zenith carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 4:45pm
The D-19 carbs I have used in the past (Marvel-Schebler, not Zenith) I drilled out the seat of the needle and seat. This is because gravity fuel flow from the tank sometimes couldn't keep up when running 2500 RPM on a 300 ft track. So, be prepared if you run fine up until the end and it seems like it might be running out of gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2025 at 5:31pm
i believe thats the very first brand new tractor carb i have had , its big old girl it clears the block by 1/8  will start updating pictures
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 8:06am
I have a WD-45 Crank I would sell. $300 plus shipping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 8:30am
have had a new 45 crank in the box for about 4years , i am useing a d17 series 4 engine that i got from the scrapper after the claw destroyed the rest of the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 8:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 8:51am
.060 above deck  head gasket composite is .065  still waiting on the head before we work on the pistons
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 9:02am
wasted money having the fly wheel of the wc turned for the ring gear it weighed 65 the wd wheel weighed 59.8 center in the wc one is solid i thought it would end up a few pounds heavyer but it came out 59.8 and the machine shop messed it up and had to weld it up and turn it agan   . my new little buddy star helping
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2025 at 12:17pm
Be sure to mark the flywheel for 15-20-25 degrees. The Fire mark is 30 degrees BTDC. 15 is half-way between fire and TDC. You'll figgure it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 8:50pm
        i uped the size of tubeing and fitttings to 3/8 just as soon as got got the carb  the 3/8 looked huge at first but that is what i was worryed about was running out of gas  iam just hoping the sediment bowl can keep up
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2025 at 10:43pm
hitch and wheellie bars almost doneuploads/8753/IMG_1028.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 6:38am
Just imagine where your pull point is going to be if by chance the pin at the front of the drawbar were to shear off. When I was a safety inspector for different clubs I discouraged drawbars with that sort of height adjustment. A cradle built around the drawbar with push bolts up and down that will allow the drawbar to slide cleanly our without changing the pull point to a higher position is much safer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 8:33am
not much to biuld to on that tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 8:45am
guess thats what the wheelie bars are for.   this is the first puller ive biult and probley the first dedicated puller in my area   their isnt much for hitches out on the inernet for hitch or wheelie bars for the wc  if  it dont work i will do somthing differant  . i should be the big fish in a little pond for a while hoping to spark a little more interest around here without spending a zillion
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 7:21pm
When you find out it is an issue, it will be too late. Just build a support attached the same as the OEM. Then make a provision with push bolts up and down.
 I've seen numerous hitches break in the past 50+ years.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 5:42am
I always thought I would like to build a set of wheelie bars that could be removed or raised by just pulling one pin on each side, similar to the way a receiver hitch on a pickup truck. The wheelie bars can be a real problem when loading/unloading. Front end goes up and the wheelie bars hit the ground.
Edited by WF owner - 20 Mar 2025 at 5:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2025 at 10:18am
the framing square and the tube clamped to it is right at 5 inches beyond the radius of the tire and 10 inch high so if i put my pad on it that will be in the rules i should be able to pull a pin and slide them up and be flush with tires and not be in the way for loading.  i am hoping the angle is enought that if you hit the wheelie bars they are skids and not rippers
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2025 at 10:00am
Hudco,  we havnt spoken for awhile.  Our conversations regarding flywheels.  yes the 45 flywheel does not have the undercut on the clutch side, but it does have less material on the crankshaft side. Have not been able to weigh them but the difference might be closer than we think, and reading you post above confirms that.
Edited by CAL(KS) - 21 Mar 2025 at 10:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2025 at 6:24pm
wc  and wd flywheel  but is a wd 45 flywheel any differant ? i dont have  one to weight i was supprised that the d17 wheel is lighter with the ring gear,  i think it was 58 lb.   by the way nice videos
Edited by HudCo - 22 Mar 2025 at 6:25pm
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 9:14am
We use two WC flywheels as weights on one of our pullers. One is for a crank starter and the other one has a ring gear. They both weigh 65 pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 9:20pm
kip i want to come down south this summer and maybe get a lesson or two at least have a little fun
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 11:48pm
We’ll have our first pull at the Washington County Fair in Hurricane on April 19 at 10:00. The Cotton Days pull will be a week later on April 26 in Washington, Utah. Then we won’t have another pull until Labor Day weekend at the Iron County Fair in Parowan. Then our best event of the year will be our two-day pull in Cedar City on October 24-25. This is held as part of the Cedar Livestock & Heritage Festival. The pull on Saturday the 25th is unlike anything you can experience anywhere else. We have a draft horse pull & tractor pull on two side-by-side tracks in the same arena at the same time!!! We’d love to have you come down. Kip (435) 592-4045
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 12:11pm
kip thanks for the chat on the phone  the other day
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 12:26pm
got some weights ready   but i need to find a oil filter base base for the d 17 series four engine lube system and also a usable distributer the inside of mine was rusted beyond rebiuling .  i have points condensors and tune up stuff also have a pertronix that i will use  ,  so far i havent found a filter base and distributor close around me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 4:14pm
Mike, I enjoyed our visit as well. Gleaner E, 170, 175 are all candidates for the parts you're looking for. Kip
