2200 disc problems
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: 2200 disc problems
    Posted: 19 May 2017 at 11:00am
The 2200 disc that I have had awhile had an extended hitch....It has broken twice...this time it broke the extra braces.....I can remake the braces..OR..does someone have a retired 2200 or 2300 with the hitch members I need??..I think they are similar...mine is 18ft but don't think it matters...Mark in Indiana
I need the two side pieces that pivot at the main frame....thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 7:34am
I guess my disc must be rare...the rest in the scrap yard...not one post to suggest another fix....I know there is no excitement about a disc...but this one is still in good shape...oh well....
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:19am
Can you post a pic of the pieces you need?
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:34am
have you studied why the hitch is breaking? is your drawbar to high or to low? maybe an adjustment on the tongue is needed? I've never had a hitch break on a disk, even on other brands. oh...and are you turning with it in the ground?
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:46am
Mark, make sure the pivot at the disc are all parraell,(in line) with each other. If they are not when it pivots there will be strain on the hitch or braces.Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 10:52am
Thanks..Mark What I need is the two main hitch irons....from main frame pivot points to the clevis...
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 7:10pm
I have a 18' 2300 hydraulic fold in northern Indiana. I would sell you the whole disc.
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
This page was generated in 0.136 seconds.
