220 Questions
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 220 Questions
    Posted: 14 hours 58 minutes ago at 7:34pm
S.N. 1988, what year would that be? And lastly, the nose cone on a 220, is that made out of tin like the 200 or is that a cast-iron nose cone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 54 minutes ago at 7:38pm
The nose is a big ole piece of cast,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 29 minutes ago at 9:03pm
...and the axle pivot block is one HUGE chunk of cast...the 210 used a hollowed out block and a tin surround.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 42 minutes ago at 7:50am
I've seen some 72 220's and they had the hollow front support like the 210.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 32 minutes ago at 9:00am
I don't know at what S/N that took place, but yes, the later 220's had the hollow front support like a 210.  Cost savings measure. You buy MORE front end weights for an 8 bottom plow.
This page was generated in 0.906 seconds.
