210/220 front slab weights
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 210/220 front slab weights
    Posted: 10 hours 52 minutes ago at 7:28am
What other models will these weights
fit besides the 210/220,going to sell
them and thought I would find out first
in case someone asks.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 12 minutes ago at 8:08am
I thought those weights fit older 170's thru 220's.  The 210/220 front support was narrowed up in the center to allow those weights to fit, even tho the side frame width was wider than the 200's on down.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 14 minutes ago at 10:06am
I agree with the good Dr.  I recall the slab weights being used on all of the one hundred series tractors (including the 200, Two-Ten and Two- twenty).
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 10 minutes ago at 10:10am
Agree. Have starter weight on 220 which came off a 190
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 11 minutes ago at 12:09pm
How many ya got?  I'd like to have some,, but dangit,, it's a long ways from here to there,, an shipping them is prolly worse driving to get them.
would you maybe going to the GOTO at penfield? I may be going. if not I might find them a ride...
