200????
smallfarmer83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smallfarmer83 Quote  Post ReplyReply Direct Link To This Post Topic: 200????
    Posted: 07 Apr 2012 at 7:58pm
Got a 1973 200 a couple weeks ago. Was working on changing all the fluids today oil, fuel filter, water separator etc. My question is were is the fill For the hydraulic fluid, rear end and tranny. And were do I fill the finals at. Im thinking they might be under the floor panels. I located the drain plugs. Is there anything else I need to check before I start using the ol girl. Also does any one know where I can located a good service manual. TIA.
CBL95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBL95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:07pm
I know on ours the hy-tran fill and dipstick is under the cover right underneath the seat the is 2 nuts just take them off and you will see the dipstick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 8:27pm
Thats right they are under the seat , floorboards ; the one one the left , as you are setting in the seat , unscrews with threads and thats the hydraulic system , the other has tabs just turn it and it will be for the transmission etc ,shouldnt say floorboards i guess , its a cover that is on the dipsticks
Edited by DougG - 08 Apr 2012 at 4:20am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 9:47pm
Finals are filled through a plug in the side of each final drive. I use a hand crank pump and fill til it runs out the plug.
Wink
I am a Russian Bot
