200 Cab fan |
Rhoadesy_65 ![]() Bronze Level ![]() ![]() Joined: 28 Jul 2019 Location: Versailles, OH Points: 151 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Sep 2019 at 8:25am |
My 200 has the factory cab without A/C. The blower fan only works in high, makes a terrible noise, and turns on and off intermittently. I would like to get it working again. Any suggestions? I had the shield off the other day and couldnt find any loose wires.
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Working only on high could be the switch. The switch has a resistor for low speed. Off and on would point to the motor drawing too much current and tripping the circuit breaker. Noise could mean a bad motor or a fan problem.
At SN 4001, there were a lot of changes. Blower motor PN 70257336 prior to 4001, PN 70256769 4001 up. These are 2 wire motors. Controls were also different.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3908 |
On ours, the intermittent problem is a loose connector at the base of the cab.
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1923 |
For starters spray the ends where the shaft goes thru with your favorite oil should help. It does help a little if you can get the fan out to do it, then you can turn it on end and let oil run down the shaft.
