200 brake lockup |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8339 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Feb 2012 at 8:31pm |
Heres the next problem on the 200 , when you step on the right brake , it locks up , no slowing down just total lock up , any pointers on this subject ?
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7496 |
Time for a brake job. That happened on my 175 years ago going in 3rd high while turning into the next row at the end of the field. It was quite a ride from what I heard!
Spring broken in brake, rusted on cast parts, or disc lining worn out or all the above. MACK
ac-mike ![]() Silver Level ![]() Joined: 14 Sep 2009 Location: Kentucky Points: 277 |
Th distance between inner and outer friction plate being out of spec can also cause lock up
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Worn out disc linings will cause the lockup
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
Check your serial number before buying. There's a split. Early ones have the 190xt style brakes with the disc and band, some have the same style used on the 7000s with the two discs and no band. The latter being much more expensive...
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
This is one of the last ones and the same as a 7000
