200 allis PD hesitation
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: 200 allis PD hesitation
    Posted: 28 Jul 2017 at 11:01pm
Nephew said his 200 PD was acting up, started all of a sudden.
  I drove it for awhile today and it is acting up.  sometimes it does not want to engage in low or high, and then wait several seconds and then slams into gear then sometimes it is like does not want to disengage and have to fan the lever back and forth till it does.
  I am guessing theres a valve sticking in the control valve body, or theres an orific plugged or maybe a broken spring in there?   Don't think the clutches them selves are causing any problems.
 Looked through the forum for some answers but came up short.  Anyone got a clue to what or where to look? thanks, JC
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 11:05pm
Have you checked all linkages to make sure there fully engaging?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 7:35am
Probably the spool sticking inside the valves bore. Possibly remove the spool and polish the inside of the bore with fine emery cloth wrapped around a 1/2" diameter redi-bolt about a foot long. Clean well and reassemble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 10:56am
Had one do that, broken clutch disc in the PD seems like it would slip and vibrate then I'm thinking the pieace became undone from another plate and it worked, don't slip it to long , hubs are becoming pricey
Edited by DougG - 29 Jul 2017 at 3:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 12:17pm
Dr. Allis had it right, stuck spool valve. Had to pry the valve out.  Did not take valve off the tractor but what I did was took an old very well worn file and magnetized it. then gently went around inside of the bore 'feeling' for any roughness. pulled the file out and there was a very thin flake of shine on the file. wiped the bore out and then inserted spool. Now it moves with just a slight resistance, whole lot better than not able to move it at all and it works good now.  It sounds very prehistoric for what I did but it got me moving again.  Thanks, JC
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 1:36pm
Awesome glad it was an easy fix ! Luv those
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 11:52pm
Me too.
 Bought an XT just prior to the seresIII on an auction back in the 70's... had two big puddles of oil under it. A couple 85cent (back then) seals in the oil cooler line fixed the leak.
