200 AC pto seals with the 1000 rpm set up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 200 AC pto seals with the 1000 rpm set up
    Posted: 25 Mar 2012 at 11:29am
When changing the pto shaft seals on a 200 with the 1000 pto setup ; do you have to remove the 3 pt arm housing to get the shaft out of the back?
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 11:38am
If it is straight 1000 rpm, no. If it has 540/1000 two speed, yes it has to come off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 11:47am
Dam ,its the 540-1000 set up
This page was generated in 0.039 seconds.
