1945 WC, + Or- Ground
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 1945 WC, + Or- Ground
    Posted: 16 Jul 2019 at 8:08pm
Got a great and straight old wartime WC. She is no parade queen, but fenders and all look very nice. Even the steering wheel is good. I have an arch frame wf for it as well as a sickle mower.
  It is still 6v and the battery was hooked up as a negative ground. Shouldn't the ground be on the positive? It has a mag and makes a strong spark, but it needs the carb gone through as it just can't get the gas up to where it needs to go.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 8:45pm
Originally it would have been a positive ground.  But at some point in its life, it could have been switched to a negative ground - not much to change it.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 11:04am
The shop manual I have in several pieces should cover battery polarity. But polarities do get changed with SAE standards about 1965 no longer allowing positive ground or 6 volts.
http://geraldj.networkiowa.com/Trees
has the WC manual at to bottom of the directory in 9 big pieces.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2019 at 4:47pm
do you have a generator / lights ? Does the battery charge correctly ?  That's your only concern.. Don't matter which way you connect the battery as the MAG dont need it and starter dont care......... but it WAS Positive ground from the factory.
