1944 WC rocker arm shaft oil tube HELP |
rickannable
Joined: 12 Sep 2014 Location: Chesterton Points: 23 |
Topic: 1944 WC rocker arm shaft oil tube HELPPosted: 15 Jul 2026 at 9:09pm |
Hello,
I need to re-create the oil tube that attaches the rocker arm shaft collar to the cylinder head. I'm not sure what size tube the original was but I believe the tube attaches to a 90 degree brass elbow at the shaft collar and then to a straight brass fitting at the cylinder head using copper tube and ferals perhaps? Not sure. Also, if I'm right about the 90 degree elbow at the shaft collar.... do I need to make sure the fitting lines up with the hole in the rocker shaft as I tighten it down, or does the oil make it's way to the hole no matter where the fitting ends up? Thank you so much in advance for any help provided! |
Phil48ACWC
Posted: 17 Jul 2026 at 3:19pm |
The oil line is 3/16" brake line tubing and the fittings are 90 degree elbow and straight 1/8" NPT X 3/16" compression fittings. Rocker Arm Shaft is Click on below:
Fittings are click on below: https://www.speedwaymotors.com/Brass-Compression-Fitting-3-16-Tube-to-1-8-NPT-90-Degree,29263.html?srsltid=AfmBOoqVmAIy6bUzO3PM0wWoZsTIukY3NDqSXG4AA-M9Sf_5Qw_HtuH6 or https://www.discounthydraulichose.com/369-03-02.html?gad_source=1&gad_campaignid=22934621220&gbraid=0AAAAAD_gh1yJGr7B9d3qKjcce-ws0F9Ki&gclid=CjwKCAjwpefSBhBvEiwAzyEtZzmEGpNokkGcQycnEe5VqlP1DVTS-JdCN7qpMs8tARtQirE0_xtX2xoCW2YQAvD_BwE or https://www.ebay.com/itm/383158384439?_skw=1%2F8+NPT+X+3%2F16+Compression+90+degree+fitting&itmmeta=01KXRW18N8ZH3X191DW14GHKFF&hash=item593604f737:g:bsgAAOSwYaZdgOkN&itmprp=enc%3AAQALAAAA8GfYFPkwiKCW4ZNSs2u11xDVJLp8B7NFvgqnsGtlSrGEYto%2BqP8knEAW7fBpHZYGujhDuOO8rzQmQu9r8a7p86R9LmtkM8KtPMB2uJO6BfToRjDTYQ1T9HasT5ondhoVkG9s6QtN9rB4qxc8Jj3H97XeuFmeRMnsba395%2F5t5SgQnnkyyiUNKGa5U5YPo56xfe8sY2Y%2F658j9AreBqSo%2F8NXU6l5%2B3ROUytAaTS6%2ButjX7BHf7Jl7CPQf3yxZTtwLRsC%2BiLn92Ap%2FkNr6O%2B1rOp2zimfoN246a58cD%2BB6BoAm7CZyQDkoKeWe92sly2HkA%3D%3D%7Ctkp%3ABk9SR-qKhZzuZw
Edited by Phil48ACWC - 19 Jul 2026 at 10:04am |
rickannable
Posted: 17 Jul 2026 at 8:30pm |
Hey Phil48ACWC.... WOW!!!
Thank you so much sir. I really appreciate it! You rule!
