1934 WC Starts but stalls out after 5-8 seconds
Griffin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Griffin75 Quote  Post ReplyReply Direct Link To This Post Topic: 1934 WC Starts but stalls out after 5-8 seconds
    Posted: 19 Mar 2012 at 2:59pm
My WC is easy to start but quickly stalls out. Pulled the plgs and they are dry. Wait  10 minutes and it fires again and then dies. While it won;t start. I tried aplug and it has fire. It acts like it is running out of gas. I reset my float bowl, cleaned up the carb, checked my gaskets. I am sure it is something I am overlooking and there are members that are reading this and laughing as they have learned the lesson. Please share it with me. Thanks for the help! Griff
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 3:04pm
Sometimes something in tank. If you could rig up a temporary tank directly to carb, that would prove or rule out that portion of the system.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 3:07pm
If there is a drain plug in the bottom of the carburetor, pull it. I'll bet you don't have much of a flow after the bowl drains. If this is so check for a plugged line.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 5:03pm
5-8 seconds won't burn up the gas in the bowl if the float is set right and the bowl is full to begin with. Have you tried to throttle it up all the way as soon as it starts or is it at idle when it dies? I think you might have a problem in the carb somewhere....Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Griffin75 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 12:39pm
Wow Thanks Team! I have the carb off "cooking" in solvent to make sure all the passages are open. I did have a tank flow issues (thanks for that one too) and beleive I have that corrected. Great Idea about a temp tank and guess what, I happen to have an old mower gask tank to use so when I get the carb back, certianly will use that too. Meanwhile, lots of practice on learning to hand crank (1st one). Next is the little C I have. Can anyone say a D14 is next to find! Just got my trialer made and painted in AC orange. Gotta love those pumpkins!! Thanks from MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Griffin75 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 12:42pm
Oh yeah.... Did the 1935 WC unstyled come fromt he factory with a gask tank sticker facing the Driver?
1935 WC, 1950 C, 1952 CA. Harleys and hit and misses are fun too!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 1:32pm
One more place to take apart. Soaking won't necessarily get to it. Unscrew the fuel line inlet adapter. Often there is a fine mesh screen on it and I've seen much younger tractoes plug that screen solid with dirt and varnish. One wouldn't pass air from my air tank showing 60 PSI on the gauge.
But in a vintage tractor every bit of fuel line plumbing can be plugged with that dirt and varnish mixture from yank to the carburetor jets. And may require a stronger attack that a mere soak. Such as reaming with a dill bit.
Gerald J.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 1:48pm
I have a few tractors that came with rubber fuel lines replacing the old steel ones.  I have found little pieces of black rubber in the Carb.  I suspect the ethanol in the fuel even though the "experts" say ain't so.   Using a small tank is a good diagnostic trick.  I use an empty oil can I call the IV bag.  Any of the plastic cans that a quart of Oil comes in will work.  drill a hole in the cap and insert a fuel hose barb.  you can find a pipe nut that will hold it in.  I never did, if you get the right size hole, the barb will just make its own threads.  Take a piece of cord or string and duct tape it to the can so you can tie it to say the top of the air cleaner.  Punch a small hole in the side of the bottom of the can to let in air.  use a sheet metal screw in the hole when you have to turn it back up'rite to transport or fill it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 4:56pm
I've bought supposed fuel hose that E-10 dissolved in a couple years. Leaked like it had been hit with a shotgun blast.
Gerald J.
