190xt transmission dilemma |
MadCow
Joined: 27 Aug 2023 Location: South Dakota Points: 189 |
Topic: 190xt transmission dilemmaPosted: 26 Jan 2026 at 11:16pm |
I have a gas 190XT, snap coupler. I prefer snap coupler, and since everything I have is gas, I prefer gas. I also like the sound of it running better. It also doesn't have the weird horse door cab where the one door opens in and the top opens out.
I have a 190XT diesel. 3pt. Recently "overhauled" (don't know exactly what) engine. It has the factory cab with the dorky doors. However. The diesel doesn't jump any gears. Goes in hard and solid and stays. The gas jumps out of second. Up hill, down hill, load, no load. With a bungie cord hooked up right it's mitigated. I put maybe 150 hours on all tractors combined a year. And I do like mechanical work. I'm slowly building up and this is the tractor that'll be growing with me. So the question is: Do I go with the diesel and swap all the snap coupler stuff over? Do I try to swap the transmissions and hitches so the gas has the best of it all? Do I calibrate my bungee cord and wait for a transmission rebuild? 1st, 3rd, 4th, reverse all work fine. And I do really prefer the gas over the diesel. This is far planning, just changes whether I sell the extra tractor now, or hold on or swap. |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4237 |
Posted: 27 Jan 2026 at 7:09am |
If I were you I'd keep both and fix the tranny in the gas tractor. Can't imagine getting rid of a good running 190 D.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1577 |
Posted: 27 Jan 2026 at 8:25am |
Those 190 diesels seem to be desirable. I would keep both in their original state. I would like one myself but unfortunately have no use for it.
A&Sfarms
Joined: 02 Nov 2021 Location: Fletcher, Ohio Points: 24 |
Posted: 27 Jan 2026 at 1:27pm |
Tractor Data says the gas uses 7.2 gal/hour and the diesel uses 5.3 gal/hour at rated speed. Something to consider since you said it will be the tractor you grow with. We are all out here waiting for input costs to come down... Plus the diesel will be cheaper to operate considering it doesn't have transmission problems. Our 7060 sits fairly often because the XT is so much cheaper to run
Posted: 27 Jan 2026 at 7:17pm |
At least remove the shift cover and take a look. Maybe you just have a broken shift fork? Wouldn't that be nice !!
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3164 |
Posted: 27 Jan 2026 at 8:48pm |
I had a gas 190XT for a few years used to bale with it,burned about 4 gal/hour
A&Sfarms
Posted: 28 Jan 2026 at 10:04am |
The 7.2 number comes from a dyno test at full load. I'm sure baling doesn't put that much load on the engine. Just using those numbers for comparison. It might not be that large of a difference at all speeds/loads, but its also not insignificant when you look at costs per acre at the end of the year
Les Kerf
Posted: 28 Jan 2026 at 11:49am |
Keep the diesel for now to use while you have the gasser torn down for repairs. Once the gasser is fixed, then decide whether or not to keep the diesel. The difference in fuel costs at ~150 hours per year total time on all of your tractors will be a minor part of your total operating expenses. JMHO, your mileage may vary
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4577 |
Posted: 31 Jan 2026 at 8:25pm |
My OneNinety Beachmaster would not stay in 4th gear when I got it. In fact, I couldn't hold in 4th gear. Removed the cover and it looked like the shift collar still some good flat surface. We moved the shift rod detent approx. .125" and now I can't make it jump out of 4th.
MadCow
Posted: 31 Jan 2026 at 11:19pm |
Thanks for the input guys!
Unfortunately I gotta get cash for seed, spray, and Fertilizer. My legs are too hairy so I'll probably have to sell a tractor instead. Where I'm at I can get really good money for tractors. I had these both shipped over 500 miles and they are both COMBINED less than a local 100hp tractor of any vintage would cost, almost. Any pointers on where to find information about this shift fork thing? Sometimes it'll go all the way into 2nd, but still jump out, sometimes it seems like it doesn't want to seat all the way in. A bungie cord between the shifter and seat fixes the issue. I do have a D15 gas as backup, unpleasant to run a square baler with though. But it'll pull the planter, rake, and cultivator. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8856 |
Posted: Yesterday at 1:23pm |
A basic test for detent relocation is to shift into gear,now see it lever will travel further when pressed into gear. Most do. Move the notch so lever doesn't have travel left. Tricky part is figuring out how much.
Edited by SteveM C/IL - Yesterday at 1:24pm |
Sids
Joined: 16 Feb 2025 Location: belleville, ks Points: 14 |
Posted: 6 hours 34 minutes ago at 3:17pm |
I like to put a small piece of play dough or some putty that will stay put between the shift collar and the gear. Put shift cover on then shift in to gear, move back to neutral, remove cover and see how much the clay is smashed. You then know how much to move the detent notch.
