190xt series 3 hydraulic pump
Allis Magoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Topic: 190xt series 3 hydraulic pump
    Posted: 15 Feb 2022 at 9:48pm
Gradually lost rear remotes when brush hogging. Then steering was intermittent. Thinking I'm not getting hydraulic flow out of the pump. No leaks on the suction side. Are the ports on top of the pump for testing? Anyone have some test procedures. I have a flow meter and all the guages. If there are port labels I Can't see any.
Edited by Allis Magoo - 15 Feb 2022 at 9:58pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 10:18pm
Check oil level first.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 5:37pm
Oil was good. Even added a bit to overfill. I did notice if I held the steering occasionally it would build pressure and the wheels would move just a bit. Same when I try to use the remotes to lift. The brush hog would shutter trying to lift every so often.
Edited by Allis Magoo - 17 Feb 2022 at 5:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 5:46pm
Two dipsticks. One on the left. One on the right. Hydraulic oil is which one ??
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 10:53am
could be low oil.
had the same issue with our 6060, I just put a pressure gage on one of the remotes and only Had about 900 psi max @ 1800 rpm. Replace the pump and everything worked fine.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 11:45am
Just got back and seen this.I was checking around to see where I could tap in and happened to notice the sump was at the torque tube....duh. not sure why I assumed it pulled from the rear when I literally just put this thing together 3 years ago and know better. You know what they say about assumptions! I hope my mistake helps someone find the thread in the future. I will say you guys are good and called it lol. The brush hog cylinder was leaky. Definitely will need to fix that because it obviously leaks more than I thought. Hopefully I didn't pre maturely wear anything. Thanks again for the great advice!
Edited by Allis Magoo - 18 Feb 2022 at 11:48am
