190xt question
Roach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Topic: 190xt question
    Posted: 11 Apr 2018 at 8:55am
Purchased a 1966 190XT gas tractor that had been parked for several years so started doing the usual. Drained fuel tank, cleaned settlement bowl, rebuilt carb, points, plugs and so forth. As I got further into the TLC I noticed that it had 2 settlement bowls, one on each side of the tank. Can anyone tell me the reason for this? Does it have a reserve of some type? Thanks in advance....
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 9:08am
It was to be sure you could completely empty the tank while working on side hills.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 9:11am
I recently cleaned up and replaced both sediment bowls on my diesel.  You need to inspect the needle valve and make sure it allows fuel even after you clean them up.  Mine were original and not working correctly.  I also had to redo the lines.
To your question though, I don't know for sure, but I think it has to do with being on a hill sideways.  If the tank was low on fuel, it would run out of fuel depending upon which side it was leaning.  Of course, if one side got clogged, the other side would help too.  Maybe under heavy load, it needs plenty of fuel too.
Not sure we have any of the original designers on this forum but it would be nice to hear from them, if so.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 10:05am
Like Dr. said.  With only one outlet you could end up sucking air if your tank is low on fuel.  I think a lot of dozers from that era also used 2 sediment bowls for that reason.
ezlle71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 12:02pm
Makes sense to me because its a flat bottom tank and working on side hills
190XT, 185, D15 SII, 7040 is living again, 7010 retired for parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 12:54pm
Thanks to Dr Allis and all who replied. Makes perfect sense. Coming from pretty flat area, just didn't think of that but knew that someone on this forum would know!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 4:10pm
And if you noticed, the left sediment bowl is forward and the right is rearward of the tanks centerline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 8:29pm
I sure did and the left one is a little tuff to clean and change gasket, especially at my age.
This page was generated in 0.088 seconds.
