190xt oil pipe spring
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: 190xt oil pipe spring
    Posted: 19 Feb 2017 at 9:01am
What is supposed to be behind the elbow fitting on the left side of the engine block? I find just a spring and no ball/plunger. Tractor is a turbo diesel. Not sure what purpose is for just a spring and find no mention or pic in book. Looks like parts book only shows th spring on then on turbo but there is a plunger? Any help would be apriciated.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 8:30pm
The 2800 block, non turbo routed the oil through the back passage.  The turbo or unit with an oil cooler , 2900 , used a spring and a plug to block off the oil and force it through the cooler then back to the block. I would suggest the plug is still in the passage.. 74020862 is the plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 8:56pm
So the plug is on he inside away from the elbow firing? I put a magnet in the passage and couldn't pull anything out. But if you reinstall the fitting you have to compress the spring.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 9:56pm
The plug gets stuck in until they won't come out.   MACK
