190xt injection line seals |
A&Sfarms
Joined: 02 Nov 2021 Location: Fletcher, Ohio Points: 22 |
Topic: 190xt injection line sealsPosted: 22 Jan 2026 at 9:45am |
Did an overhaul on the engine including injection pump and injectors for my 190xt 2 winters ago. The kit came with white plastic washers for the banjo bolts on the injection pump and some have always leaked, but the leak is getting worse. Bolts were torqued to spec upon install and have been tightened up as far as I feel comfortable since trying to get them to seal. I went to the dealer and they had aluminum washers with a smaller plastic washer inside as replacements at a cool $20 per washer. Needing 12 of them bad boys was going to cost a pretty ridiculous amount. The parts guy pointed me to a Deere dealer with what looks like a black oxide washer for $0.13 a piece. That was cheap enough for me to go ahead and buy and see. It has been way too cold for me to get them installed yet. Do you guys have the answer on this? Are the 2 piece, $20 washers the answer for a good seal? I was expecting copper, but no one offered that.
Posted: 22 Jan 2026 at 10:36am |
Black. Get them tight.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8810 |
Posted: 22 Jan 2026 at 10:48am |
black Deere one are what you want. Everything clean of course. Book say 35 ft lb IIRC. It's a scary pull and some impossible to get a torque wrench on. I do by hand and get em tight as Doc says.
A&Sfarms
Posted: 22 Jan 2026 at 11:30am |
Thanks guys. Good to hear I ended up with the right ones then. And the cheap ones for a change! Definitely didn't tell the Deere guy what I was working on.... just in case.
PaulSamwel
Posted: 22 Jan 2026 at 11:59am |
Working on a 185 with pump issues.Would those Deere seals your talking about be part number T20055?
KJCHRIS
Posted: 22 Jan 2026 at 3:04pm |
I had a pump off a few months ago. I came from pump shop with 12 of the black metal washers for the banjo bolts. just like they have for 50 years.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2465 |
Posted: 22 Jan 2026 at 5:37pm |
Paul,yes, that John Deere number seems to be correct. Also yes, that type of sealing washer is the kind to use.
PaulSamwel
Posted: 22 Jan 2026 at 5:42pm |
Thanks for the reply Lynn!
DougG
Posted: 22 Jan 2026 at 6:35pm |
Sometimes you have to tighten them up,, loosen then retighten,,,
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3594 |
Posted: 3 hours 40 minutes ago at 11:03am |
I have never seen anything but single steel washers -12 of them. Some were silver colored and some black. They are soft enough to deform and seal. I would doubt any non-metallic seal to hold the pulses at 3000 PSI +
