190XT - Fuel issue |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Topic: 190XT - Fuel issuePosted: 13 May 2017 at 9:47pm |
Could be lots of crud in the tank that blocks the outlets on occasion. Mine had a lot. Don't just look at the sediment bowls. If everything is good there, I would start looking at the injector pump. Might be giving up the ghost little by little.
Sundre roper
Joined: 10 Oct 2016 Location: Sundre, Alberta Points: 6 |
Posted: 13 May 2017 at 9:45am |
good day all, I had the occasion to run outta fuel this spring (yup stupid me) Regardless I am having a hard time getting the old girl back running consistently. I have changed fuel filters, cleaned (both) sediment bowls, bled out all the injectors etc. to this point. What occurs is I can run her for anywhere from an hour to four hours and all of a sudden the motor loses power and will stall. I wait a matter of minutes and restart with no problem. My question is: what else should I look for, clean, or perhaps need to replace?
