190XT 5th gear
carpenter972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carpenter972 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT 5th gear
    Posted: 29 Jun 2011 at 6:30pm
I bought my first AC this spring.  It's a nice 190XT Series III diesel with 4300 hours, cab & loader.  I was aware of the gear popping issues & when I tried out the 190 I could not get it to pop out.  Of course the owner said it was a good tractor with no gear issues.  I was cutting hay with it yesterday, came down my first of many steep hills and it popped out of 5th gear.  I have some more gradual hills and it did not pop out going down those hills.  From doing some other searches, it sounds like some major work to fix it.  I had split some smaller tractors, but I think this may be over my head.  I do have a AGCO dealer a few miles away and plan on getting an estimate on prices.  I'm guessing $3-$4K.  Can anyone give any better insite on this issue, or does anyone know any good small repair shops in the eastern WIS area?
Thanks,
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote carpenter972 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 6:33pm
Here is a pic of it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 10:12pm
That is one sharp original looking 190.  To do the job, most of it is labor.  The parts to look at include excessive wear on the shift fork, and up and down movement of the input shaft (sloppy bearings in the tranny) - these are the main items that cause gear jumping.  Prices from AGCO can be high, but A&I also carries replacements that are more reasonably priced.
Good luck.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 10:50pm
Welcome to the forum and may I say you have one fine looking building to store those orange tractors. A friend of mine re does something to the shifter linkage to fix the problem but this is a quick fix and not the right fix.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2011 at 8:57am
I put a tarp strap on mine for several years. Worked for me.
ACFarmer86 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2011 at 10:56pm
I just had my 190 XT III apart for the same reason.  It was not too hard just alot of time.  I put in ac gears instead of aftermarket (was told they were soft)  two gears seals and oil was about $1000.  All the bearings were still good.  dealers and shops around here said about 1600 for labor. Hope this helps
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2011 at 5:57am
A few years ago a buddy of mine bought a 170 with that problem and he took it to an independent shop that fixed it for less than $2000 but I don't know what he had done to it.
Wink
I am a Russian Bot
