190 XT reverse shift lever |
Post Reply |
festus
Bronze Level Joined: 03 Nov 2011 Points: 83 |
Posted: 3 hours 44 minutes ago at 6:49pm |
Broke the lever today. It looks like these are almost impossible to find. My tractor appears to be a 64 XT gas. I see where some have been able to braze them or in some cases weld them back together. This one broke on the flat part a little above the numbers. I'm a little Leary of brazing it and expecting it to hold. Make I am overthinking it. I am assuming it is cast steel so welding may be a decent option. I have an Ac stick welder and A wire welder which I assume is a no. Will An old fashioned Lincoln Ac buzzbox work for the needed rod? What rod would you recommend? Will another shift cover with the levers attached interchange with mine? I found a case where a guy found another lever from a yard , but it was different than his. My rails were rebuilt 6-8 years ago so I would prefer to use it if possible. The part number on mine is 246554 Thank you for any suggestions |
Joe Goodwill
Bronze Level Access Joined: 12 Sep 2009 Location: Souris Manitoba Points: 87 |
We broke the reverse shift fork on a 185 30+ years ago on a weekend during a blizzard! Opened it up took the fork to local shop where old AC mechanic worked. He was a master with brass and a torch. 15 minutes to fix 1 hour to enjoy the bottle of dark rum payment and it is still working today. Don’t be afraid of a proper brazing repair.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8406 |
246554 looks to still be available
elmer
Bronze Level Joined: 25 Oct 2019 Location: mid west Points: 29 |
Thanks Joe . That gives me some hope if it comes down to that. I used to have to braze together 2 oil pick up tubes on Chevy race engines years ago. It has been several years since I have had to do any brazing.
Post Reply | |
